Hi CC,
This is most definitely possible. There are a few important things to note when installing your second instance. You'll have to ensure that the second instance has unique identifiers. This means it needs it's own file path, database name, conversion server path, and web alias. Each install will create a new database and each instance of innovator will have it's own vault. Going through the installation documentation in the 12 CD image should help you figure out how to set each one of these individually. It should be pretty straightforward, but let me know if you have any issues!
AJ
Hi
I made sure the second instance has unique identifiers but when trying to connect I get an error
"Error: Cannot access OAuth Server due to 500 (Internal Server Error)"
I checked the xml config files and don't see any mismatch with server names,etc.
Any hints?
Regards
CC
- asebastian7 years agoCommunity Manager
HI CC,
Can you verify that the version of .NET Core installed on the machine matches the version which is a prerequisite within the installation documentation?
- cc9117 years agoIdeator III
Hi
Thank you for your help.
I did not read properly the prerequisite (sorry), performed install of the good components.
But it's still not working, i now get en error:
"Error: Cannot access OAuth Server due to 502 (Bad Gateway)"
Best regards
CC
finally solved by using the right asp.net core.
thank you again
cc
- gbangs7 years agoIdeator I
Same error, but only trying to install v12 in testing env. .Net Framework, Core, Runtime, Hosting versions, all confirmed - yet, still 502 Bad Gateway. Any thoughts?
Thank you,
g
- rocky7 years agoIdeator I
Don't install the latest version from Microsoft, install the exact version mentioned in the installation guide (.Net core 2.1.8)
