8 years agoCommunity Manager
Hi Maddy,
I had initially thought your use case was only between individual users and not between Alias Identities.
In this case, I would recommend looking at this post in the Aras knowledge base which covers how to dynamically assign permissions to an Item based on item properties. To make this fit with your use case, you could pull what the "created_by_id" of the Project is and check to see if it is a member of either Project1 Users or Project2 Users.
If the user who created the project is a member of Project1 Users, you can give all Project1 Users edit permissions. Likewise, you can give all Project2 Users edit permissions if the user who created the project is a member the of Project2 Users group identity.
_________________________________
