mouad's avatar
mouad
loging failed Aras innovator 11 sp15
Hello All,
I do a successful installation using an existing database 'X' but I encountered an error :
When i restored the  database 'X' and finished the installation, i run all the sql scripts without error except the first one:
Even if I mount the user innovator_regular from Sql Server, db => security => logins => right-click innovator_regular, go to properties, assign it to the database 'X' in the User Mapping property and run again the query successfully(see pic below). The probleme still persist when tried to logged in (Invalid object name 'LOCALE'.).
NOTE: i am able to connect using the InnovatorSolutions database.
  • Hi,
    change your browser language to English and try to login again. You should be able to login. Then go to LOCALE itemtype and throw out the invalid entry.
    Had the same issue at last Aras update. When you use a language pack, Aras will throw in their own Locales, which conflicts with the existing ones that you might have created by yourself.
    • mouad's avatar
      mouad
      Hello Angelap,
      Thank you for your reply,
      The browser langiage is in english, and i am able to connect with InnovatorSolutions database but the probleme still persist with the restored database (X)  !
  • Hello All,
    As discussed with SunilReddy in the session, we have done the needfull as all tables are added to database 'X' by connecting with innovator_regular. But we have faced another issue (see pic below) when tried to login in with admin, innovator
    Any Help please ?
      • mouad's avatar
        mouad
        Usualy, It should  be created automatically during installation but it doesn't when I install with (use an existing database).
        FYI: the instance i am trying to restore on aras 11 sp15 was installed on aras 11 sp10.
        Is there an impact on the connection if I haven't restored the code tree? according to my knowledge the connection(admin > innovator) must be established even if I have not yet restored the code tree or the vault, am i right ?
        I have just refresh the browser, try connecting again, i faced another issue !!:
        Any help please ?
