9 years ago
Installing the software on a single PC
Hello, Is it possible to install the software on a PC without using a server? If it is, is there any tutorial available concerning this kind of installation? Thanks, Guy
  • Guy, Yes you can install Aras on a single PC (this is not supported or recommended configuration) . Just use the installation guide for the server (from the Download section of the website) on a single PC. Keep in mind that you need to make sure that you installed IIS + .NET (check the documentation for the relevant version) before installing Aras
  • Zahar, thank you. Do I need to install the SQL server as well?
  • If you want everything to run on the same PC, the answer will be YES. You can use SQL Express version
