tcarozza
6 years agoIdeator I
For your reference, the IIS not working issue occurs due to installing the prerequisites in the incorrect order. Please follow the steps below to resolve that:
- Uninstall the following to ensure a clean server
- Aras Innovator
- IIS
- Microsoft Visual C++ Redistributable 2015
- .Net .Net Framework 4.7.2
- Microsoft .NET Core Runtime – 2.1.8
- Microsoft .NET Core 2.1.8 – Windows Server Hosting
- Install IIS using the following steps (you will receive 500.19 error if you do not select the features below):
- .NET Framework 4.5 Advanced Services
- Windows 8 / WS2012 or higher
- For lower OS versions, .NET 4.0 or 4.5 must be installed separately
- Static Content
- Windows Authentication
- ASP
- ASP.NET 4.5
- Just “ASP.NET” in lower OS versions
- Install the following prerequisites (in the order listed):
- Install Aras Innovator 12.0 SP6 using the steps outlined in the Aras Innovator Installation Guide
- slohning6 years agoIdeator I
I will try this and let you know how it goes, is there any reason to install 12.0 SP6 rather than the SP9 version ?
After trying all of the above a few times, i.e. deleting them and reinstalling them and adding aspnetcore-runtime-2.1.21-win-x64 it finally appears to work.
Thank for all the help, one question does .NET have a dependancy checker program.
