PriyaB's avatar
PriyaB
Identities Display hierarchy
Dear All,
I am new to ARAS and trying to learn the application.  I was able to install ARAS with the help of documentation and this site and get going.
I created an Identity for a fiction Organization - ACME. I created 2 Identity ENGINEERING and MFG and made these member of ACME.
Now I created an User and added the user as a member of ENGINEERING Identity.
Is there a way I can look at this structure hierarchy. ie, ACME=>ENGINEERING->User in the Interface.
If I login as user, Where I find that I belong to ENGINEERING and Its parent ACME.
Thanks ,
Priya
  • Open your own Identity or user (Click where ever your user name shows up in Created by or Modified by or Assigned to fields). Goto View --> Where Used. You should see the tree structure. If the tree is not expanded by default, you should click on Expand All.
    Or if you Open the top level Identity- ACME. Goto View --> Structure Browser. You should see the tree structure. If the tree is not expanded by default, you should click on Expand All.
    • PriyaB's avatar
      PriyaB
      Thank  you for your response.. I was able to view the Structure Browser.
      Also.. I can also see where used..
      But as a User.. I see only the below.
      I would like to know, from where I can see as an User that I am belonging to Engineering of ACME.
      Thanks again
