Alexandrecimp
6 years agoIdeator III
How to build an aml request using a request in a request ?
Hello Aras Community,
i am would like to perform this SQL request but in using AML :
Innovator _innovator = this.getInnovator();
StringBuilder sql = new StringBuilder();
sql.AppendLine("SELECT ID, ***_code, config_id, state, Major_Rev, Generation, is_current FROM innovator.[***_ROOT_***] ***1 WHERE ***1.generation =(SELECT MAX(generation) from innovator.[***_ROOT_***] ***2 where ***2.state = 'Working' AND ***2.config_id = ***1.config_id)order by modified_on");
Item ***_result = _innovator.applySQL(sql.ToString());
return ***_result;
Basically i need to do a request in a request.
Do you think this is possible ?
thank you so much for any help.
