Sathishkumar_C's avatar
Sathishkumar_C
9 years ago
How to add Corporate Time Zone?
Hello everyone, When Client or Employees login to different time zone they must know the corporate time zone. So, I want to add corporate time zone in Aras PLM. Can you help me. Thank you.
  • This is the right way to do it (you don't even have to restart IIS). Have you actually selected a different timezone on your client to see the difference? I just tested it, my client is on paris timezone and the corporate timezone is India Standard Time and it works. I tested it on 11SP7 but it should work the same way on open releases like SP5 and SP9
  • I followed these steps but i didn't get a solution. To set the Corporate Time Zone please use the following steps: 1) Log into Aras Innovator as an Administrator 2) From the TOC, select Administration\Variables 3) From the main toolbar, select “Create a New Item” 4) Set the Name = CorporateTimeZone 5) Set the Value = India Standard Time 6) Save, Unlock, and Close the Variable Item 7) Log out of Aras Innovator 8) Restarted mt IIS server.   Help me.
