asebastian
6 years agoCommunity Manager
Hi iGacky,
I tried logging into a locally installed instance of Innovator without an internet connection. I was able to see the same window with the same information, but after I closed it, I was able to access the instance as normal. Is this your first time attempting to log into the server? It could be like you said, and that the first login requires some sort of validation, but I'm unsure.
When you ran the installer were you connected to the internet? I believe some validation of the framework license happens during the installation process, so potentially if you didn't do it there you could run into issues down the line.
AJ
