Maddy's avatar
Maddy
8 years ago
Ho to change task list if user vote delegate
Hi, I want to change the task list when user delegates his task to some other user. So, is this possible to generate dynamic task depends on the vote that registered by the user?   Thanks and Regards, Maddy.
  • Hi Maddy, It's not possible to dynamically assign tasks like this, but it would be possible for each vote to lead to a different activity in the Workflow Map. You could then specify a different group of tasks on each activity that is appropriate to the vote that led to it. Would this meet the requirements for your use case? Chris
  • Thank you Christopher for your reply. Actually, now I removed the tasks from Activity, and ask the user to manage the follow up on comments that we give at the time of completion of the tasks. Because of the user who gets the delegated task does not come to know that why the task is been a delegate. I will try the solution as you said.   Regards, Maddy.
