sameerbaji's avatar
sameerbaji
Ideator II
9 years ago
First Login Page not display correct
Hi All, I was logging first time to Aras but getting error in loading Login page saying, Resource with key="'login.version_html'" is not found in "">localhost/.../ui_resources.xml". 11.0 SP9; Resource with key="'login.build_html'" is not found in "">localhost/.../ui_resources.xml". 6549 Please any advise on this?
  • eli_donahue's avatar
    eli_donahue
    Hi sameerbaji, It sounds like the server configuration is missing some components. Can you confirm ASP and ASP.NET are installed on the server? You may need to restart IIS after updating the configuration.
  • Why would ASP.NET be needed? It isn't a dependency, is it? The installation manual doesn't mention that as a requirement at least.
