user123's avatar
user123
Ideator II
Event Handler Failed OnInsertRow
Hi
I am new to Aras so i dont really know what am doing. However i have been working on a small project where i require a row event.  when i add the below code to the Relationship type with the event handler OnInsertRow i keep getting an error.  can someone please help me i dont know what am doing wrong.
var parent_item = parent.thisItem;
var parts = parent_item.getRelationships("parts");
var newItemNum = parts.getItemCount();
setRelationshipProperty(relationshipID, "sort_order", newItemNum);
Thank  you
  • Hi
    I assume you are trying to update sort order of a relationship. Can you confirm the relationship name is correct. You can go to Administrators --> Item Type --> Search Part and see what is the exact relationship name under relationship tab.
    Lets assume you are updating the Part BOM, then your code should be:
    var parts = parent_item.getRelationships("Part BOM");
    Thanks
    Gopikrishnan R
    • user123's avatar
      user123
      Ideator II
       Hi
      Thank youy so much for replying,
       So i have main item type called Design_Parts  with has a relationship with part_List and that has a  relationship item which is called Design_Part _list . so as far as my understanding goes i have  gone to my DesignPart itemType clicked on Relationship and  clicked on  view relationshipType. In there it has a tab called Grid event and thats where i have maneged to  put this.
      so my code goes something like this but currently it doesnt do anything apart form give me a eror.
      var parts = parent_item.getRelationships("Design_Parts");
       I want something like the screenshot below . so when the end users add partsit will automatically be like part 1 part 2 so on. and currrently its not doing that and i dont understand where am going wrong.
       Again thank you soo much for your help.
      USER123
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi
        In this case, the relationship should be 'part_List'. Also ensure that you want to update the sort_order column or item number column.
        var parts = parent_item.getRelationships("part_List");
        Thank You
        Gopikrishnan R
