8 years agoAccelerator III
Error: Variable 'Component Engineering' should not exist in the DB
We're getting this error when trying to install Aras Component Engineering : Aras Innovator Database Updates
2018-06-04 12:45:06,228 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking package started: 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321\package.config' 2018-06-04 12:45:06,241 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking package finished 2018-06-04 12:45:06,260 [7] INFO Aras.Tools.ArasUpdateGui.Logger Installation of the package started : 'CE' from 'C:\ProgramData\Aras\ArasUpdate\CE\11.0.1321' directory 2018-06-04 12:45:06,267 [7] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage started 2018-06-04 12:45:06,274 [7] INFO Aras.Tools.ArasUpdateGui.Logger Checking module 'DB' compatibility. 2018-06-04 12:45:06,280 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,307 [7] INFO Aras.Tools.ArasUpdateGui.Logger Variable 'VersionServiceUpdate' is found in DB.The value : '0'. 2018-06-04 12:45:06,313 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,319 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,345 [7] INFO Aras.Tools.ArasUpdateGui.Logger The innovator DB contains AML package with name : 'com.aras.innovator.solution.PLM'. 2018-06-04 12:45:06,352 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,360 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application started 2018-06-04 12:45:06,385 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Variable 'Component Engineering' should not exist in the DB.} 2018-06-04 12:45:06,392 [7] INFO Aras.Tools.ArasUpdateGui.Logger Application finished 2018-06-04 12:45:06,397 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,403 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP9'. 2018-06-04 12:45:06,430 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-06-04 12:45:06,436 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,442 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,449 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP11'. 2018-06-04 12:45:06,479 [7] WARN Aras.Tools.ArasUpdateGui.Logger String[] {Incompatible version of Innovator} 2018-06-04 12:45:06,486 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,492 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence started 2018-06-04 12:45:06,498 [7] INFO Aras.Tools.ArasUpdateGui.Logger Required version of Innovator : '11.0 SP12'. 2018-06-04 12:45:06,524 [7] INFO Aras.Tools.ArasUpdateGui.Logger InnovatorDependence finished 2018-06-04 12:45:06,534 [7] WARN Aras.Tools.ArasUpdateGui.Logger Variable 'Component Engineering' should not exist in the DB. 2018-06-04 12:45:06,541 [7] INFO Aras.Tools.ArasUpdateGui.Logger CompatibilityPackage finished 2018-06-04 12:45:06,547 [7] ERROR Aras.Tools.ArasUpdateGui.Logger Aras.Tools.ArasUpdateCore.Implementations.Commands.CheckCompatibilityPackageCommand: Variable 'Component Engineering' should not exist in the DB. 2018-06-04 12:45:06,556 [7] INFO Aras.Tools.ArasUpdateGui.Logger Operation 'Install' failed
