Hi YoungGo,
Could you please take a look at your OauthServer/Oauth.config file? Towards the bottom of that file is a list of redirectUris. Could you check to make sure that the value between your ip address and /client/ is InnovatorServer, like you have specified above? The error seems to indicate that somehow the redirectUris were misconfigured.
AJ
Hi AJ,
Thank your reply. Please see the attached file and screenshot
I check My OauthServer/Oauth.config file
<redirectUris>
<redirectUri value="iomapp://token/"></redirectUri>
</redirectUris>
I didn't see the URL(http://localhost/InnovatorServer/client) on Oauth.config.
When I input http://localhost/InnovatorServer/client on chrome browser,it just like the screenshot shown below.
[View:/cfs-file/__key/communityserver-discussions-components-files/6/OAuth.rar:320:240]
I had the same problem. This section of the OAuth.config file had all the URLs. If I entered one, for example "http : //localhost/PPU/Client", in the Browser, it worked. So I just added the yellow marked lines with the URL I needed, and now I don't get that error anymore.
I hope this helps.
Regards
