Good morning Chris,
this error message appears, when I started to connect to the Arras Innovator login page.
Bjorn
Hi Bjorn,
Did you install the OAuth Server and Innovator Server together under the same location or was this a separate install?
The first place I'd recommend checking is the InnovatorServerConfig.xml that you can find at the root of your installation directory. This config file has a URL inside of the <OAuthServerDiscovery/> tag that should point to the URL of your OAuth Server. The default value here should be fine if you've installed the two components together, but for good measure, you can try hard-coding this URL.
For a default installation, the URL would look something like:
localhost/.../OAuthServer
But for a separate installation, the URL will be based on the machine name where you've installed the OAuthServer.
- BMJ20206 years agoIdeator II
Hi Chris,
I installed both, OAuth and Innovator Server, under the same location via the Aras setup wizard. The path is this:
C:\Program Files (x86)\Aras\Innovator12
I try to connect the browser to this site: localhost/.../
This is the content of my InnovatorServerConfig.xml :
<OAuthServerDiscovery>
<Urls>
<Url value="$[HTTP_PREFIX_SERVER]$[HTTP_HOST_SERVER]$[HTTP_PORT_SERVER]$[HTTP_PATH_SERVER]/OAuthServer/"/>
</Urls>
</OAuthServerDiscovery>I also get the error with this configuration:
<Urls>
<Url value="">localhost/.../>
</Urls>
</OAuthServerDiscovery>Bjoern
