Same problem here. Did you sort it out?
Hi Duncan and Fabio,
I believe I have run into a similar issue. This is an issue with Windows installer, in my case I ended the installer task during installation and received a similar error. Have you tried re-registering the msi? You can try this by opening a command prompt as administrator and typing in the following command: msiexec /unregister, then press enter. Then to re-register type in the following command msiexec /regserver. After this try the installation again.
Hope this helps!
Nithin
- Duncan6 years agoIdeator I
Hi Nithin.
Sorry didn't fix my error. Ran the commands exactly as you have described then reran the installer and got the same error.
- raghubudarp6 years agoIdeator I
Hi Nithin,
I am facing the same problem and above answer did not help.
- Nithin_Mahesh6 years agoCreator II
Hi Raghubudarp,
Unfortunately I am unable to recreate this issue, but I am unsure if this is related to a windows installer issue or something with the msi being corrupted. Are you able to install other programs? Have you tried re-downloading and running the same msi?
Best,
Nithin
