9 years ago
Document properties
Hello, I am new in Aras and I am trying to understand how it works. I would like to ask you about the properties that a document have. I created a document and I also added a file type, now which is the workflow that should be followed in order to change the State & the Revision of this document? Thank you in advance!
  • Hi Maria, Once the document is created and still in the draft mode, you need then to create an ECN to release it using CMII change management standards. If you go in help-> just ask innovator You will access the help document In the menu select : Product Engineering -> CMII Change Management -> The ECN You can also look at the simplified change management Hope this helps !
  • Thank you for your answer, in order to complete this process (ECN or ECO) I need to be the administrator? Because when I 'Submit ECN' I don't have it in ' My InBasket'.
  • Not an admin, look at the workflow process and select the active activity, you will see to whom the assignment is given.
  • So firstly the Admin should 'connect' one of the identities with a member? (for example Change Specialist II with a person)
