eli_donahue
8 years agoCommunity Manager
Hi Duygu,
Angela is correct about the potential dangers of modifying previous versions of an item via direct SQL. If you absolutely have to modify data via SQL, it's a good idea to backup your database first so you can roll back if necessary.
If this data is in a production system, it may be better to contact Aras Support ([email protected]) to see if they can help you correct the data with a less risky approach.
Eli
