- EricTD2 years agoIdeator II
Hello Chris, Thanks for this confirmation, I was getting errors when trying.
But does this behavior not undermine good programming practices?
So rather than modifying the existing ItemType, you copy the original and modify the copy.
The name of the copy would then also start with a company/client specific prefix.
Is there really no better alternative? Perhaps only for subscriberss?
As a note; I once ran into an error because I was able to SaveAs an Item but run into the maximum length of the name and hence was not able to create a copy. So the max length of a name can also be a limiting factor.- angela2 years agoCatalyst II
Chris is unfortunately no longer at Aras. But we all wait for his return.
In general there are a few scenarios where Save As is not recommended to be used (even if Innovator doesn´t prevent it).
But "Copy "an ItemType is something I would avoid at all cost
When you create an ItemType, automatically a couple of sub items are created, especially Form and CUI elements.Your custom prefix that you assign afterwards will not affect the underlying items. So you have to rename all of them, otherwise your database will become a mess.
This is also the reason, why you should choose your ItemType name wisely at the start, cause you should avoid to change an ItemType name at all cost (for other elements it´s most of the time no problem).
If you really want to build a clone of an ItemType, do it via AML or packaging. So export the ItemType and then modify the file (name + ids). But this most of the time don´t save you much time compared to manual building.
