Hi Duncanwilliamgibbons,
I am not too familiar with upgrade within Aras Update, however were you able to confirm that you are pointing to the package.config file within the SP?
Best,
Nithin
Hi Nithin, thanks for the response.
How would I ensure this?
- Nithin_Mahesh6 years agoCreator II
Usually when using Aras Update any package you are giving it should come with a package.config file. The zip file you are using, did it contain a package.config?
Another thing I can think of that might cause it to throw that error even if you are pointing it to the config file is maybe a permissions issue if you are extracting this file to (x86). Try extracting it to another folder with less permissions.Best,
Nithin
- Duncanwilliamgibbons6 years agoCreator I
I extracted it on my external HD, but don't see a package.config file, not even when searching within the .zip file.
Hi Duncan,
Just for better understanding can you tell me where you got the CD package from? Normally its within the patch zip file that comes with the CD Image.
Thanks,
Nithin
