Any work around?
Hi Duncanwilliamgibbons,
I am not too familiar with upgrade within Aras Update, however were you able to confirm that you are pointing to the package.config file within the SP?
Best,
Nithin
- Duncanwilliamgibbons6 years agoCreator I
Hi Nithin, thanks for the response.
How would I ensure this?
- Nithin_Mahesh6 years agoCreator II
Usually when using Aras Update any package you are giving it should come with a package.config file. The zip file you are using, did it contain a package.config?
Another thing I can think of that might cause it to throw that error even if you are pointing it to the config file is maybe a permissions issue if you are extracting this file to (x86). Try extracting it to another folder with less permissions.Best,
Nithin
I extracted it on my external HD, but don't see a package.config file, not even when searching within the .zip file.
