phoebe_uman's avatar
phoebe_uman
2 months ago
Changing File Type Column Width in Relationship Grid
Hi all,  I'm trying to change the default width of the "File Type" column in all relationship grids. I was able to change "Related File" within the relationship itemType (related_id), but when I giv...
  • Hello
    For this you need the update the Item Type which is Relationship = True
    In this example, it is the File relationship from CAD (CAD as source_id and Files as related_id)
    there is a column width where you can set values.
    (If it does not show properly after change, you may need to clear cache of your web browser)
    This will set the default value for all users.
    if you want to do it just for yourself, you can save the layout of the Files relationship grid:
    Manually enlarge the width, and save the layout
    regards
    Michael
