8 years ago
Aras Update Failed to get packages.
Hi, When running Aras Update we get the message "Failed to get packages. Error: The remote server returned an unexpected response. (400) Bad Request." We are not using a proxy of any kind. Is it working for other users?
  • eli_donahue's avatar
    eli_donahue
    Hi smtp_fan, That error is probably the result of some brief maintenance our IT department just ran on Aras services. If you try again do you get the same error? Eli
    eli_donahue
    Hi smtp_fan, Actually, I am able to confirm the error you are seeing. I have notified our IT team and will follow up when the issue is resolved. Eli
    eli_donahue
    Hi smtp_fan, Our IT team has resolved the issue with the Aras Update service. You should be able to access the online packages again. Eli
  • Hi Eli, Thanks for getting that looked at. All working our end again.
