There are 2 things:
1) Using Aras with MAC
2) Running Aras in server
- Aras is using IIS to run. And IIS runs on Windows servers (or Windows installation in general).
- And as far as I know (not a MAC guru) IIS is not supporting MAC
- You might be able to utilize some virtualization platforms to run windows on MAC (VirtualBox?)
- Or there might be some other projects regarding running Windows/IIS on MAC.
- But Generally - out of the box, you cannot run (Aras server with IIS + MS SQL) in MAC. It needs Windows.
About developing - If your Aras is running on some server and you utilize the browser in MAC - then it's possible to develop Aras - Aras uses a lot of 'internal' methods and there is 'internal' method editor (used in a browser) where you can write those methods (with javascript and C#).
Hopefully this makes this issue a little bit clearer.
Cheers,
//Jukka.
