Another 500 error, ARAS Innovator 12 installation
Hello, I am following the ARAS 12 guide and I have the following system/features setup
Applications/Versions:
Server Roles:
The features:
The System:
Logging on to SQL Server (mixed mode authentication) with the SA account.
I am navigating to the localhost thru IE
Any help would be appreciated!
Justin.
    • Former_Member's avatar
      Thanks for the reply. I have those features installed/running and that is the web address that I am trying.
      In that blog, what is the OS where those menus are found? I am using Server 2016 and I don't have those boxes to check.
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        I didn't get you. Are you talking about the Turn Windows Features On or Off check boxes ?
  • asebastian's avatar
    asebastian
    Hi Justin,
    Just looking at your screenshots it would appear that you have an older version of the .Net framework than what is required in the Install Guide. Please ensure your system has the following versions of the .Net framework and the ASP.Net Core bundle.
    AJ
      Thanks for the reply. I have installed 4.7.2 prior to receiving this error, and verified in the registry that it is installed. Do I need to uninstall older versions? I am not sure why it does not appear in the windows features checkboxes.
