Ambiguous Error/Missing columns
I recently configured a few databases today in addition to the canned innovator solutions db.  Throughout the process I needed to delete a database and reconfigure the exact database with a user id change.  I deleted the wrong database, then deleted the correct one.  After attempting to reconfigure the required db's, setting the tag in the config file, and attempting to login I get the following error:
Cannot find either column "protected" or the user-defined function or aggregate "protected.getProtectionToken", or the name is ambiguous.
It is my hope that Mr Gills doesn't tell me to read the book, although I would certainly be appreciative.
Thanks for reading.
  • Like magic I was able to get into the DB's without re-configuring aras.  Do not know what the issue was.  Perhaps the server took off early for the weekend, who knows.
    • christopher_gillis's avatar
      Hi Rob,
      I don't think this one is covered in our documents. :)
      If I had to take a guess based on the description of the problem and the sudden resolution, I'd say this was probably a caching issue. When you were configuring the new databases, was one of them restored with the same name as a database that was previously deleted?
      • Former_Member's avatar
        The method we have found best for adding and deleting databases is to:
        Run Installer>select add database and all its features>Configure database via aras Installer>cancel installation of aras>Edit config tag with appropriate information: ie, copy and paste most of the connection tag with the credentials being different. Log in.
        My Actions:  At first I assumed I needed a different users for each different db in aras, so I started with innovator1, innovator2 ect as a user.  I didn't not make it to innovator2, I found this to be a needless step.  So I deleted the database I built with innovator1, rebuilt the database via aras MSI naming it the exact same database, which as I type I realize the cache explanation make a ton of sense.  Anyway after naming the two databases I deleted the exact name as they were before, setting the tag in the config file and attempting to login prompted that error.
        Mr. Gillis, as always I am very grateful.  I hope I was clear and helpful.
