8 years agoCommunity Manager
Hi Rik,
The data you're looking for is actually stored in the related_id property of the Workflow Map Path. The Workflow Map Path is a null RelationshipType, but if you inspect the properties on the ItemType, you'll see that the related_id does exist.
I'm not personally sure of why this is the case. If I had to make an assumption, I'd say that this was for legacy purposes as the Workflow Map is one of the older ItemTypes in the standard Innovator platform.
