8 years agoAccelerator III
Dear Christopher,
many thanks for the quick answer!
The proposed solution works perfectly.
I have another question, which also refers to the relationship structure of the data in the context of process modeling.
Unfortunately I don't understand how the relationship between two Activity Templates is defined using Workflow Map Path. I have tried to show my current findings in the illustration.
Where is defined on which Activity Template a path points to? In my opinion it would be logical that this is referenced via the "related_id"-Property of the Workflow Map Path instance (Item Type). In a query, however, this value is always null. Also the Related Item Type of the Workflow Map Path is not defined.
I hope I can explain my problem properly. Many thanks and greetings
Rik
Rik
