8 years ago
Why not fix the bug?
Do you know the onChange bug in version 12? It was not fixed at all in the temporary version 14 In addition, in version 14, an error was found that the item that was searched previously was found in the basic search. This is a very serious bug in using it. 14 version has not been released yet When it is released officially, I hope it is all fixed. Thank you.
  • eli_donahue's avatar
    eli_donahue
    Hi jing9, Can you describe the OnChange bug you're seeing? Also, can you clarify what you mean by "temporary version 14"? Aras 11 SP14 was released back in May. Thanks, Eli
  • Describing the Onhange bug 1. In the filed tab of form, Add a Method. And then select Onhange as Method's activation condition. 2. Even if the value of that field is changed after opening the corresponding form, the method doesn't work. For example, if a date type of the Property which Onchange occurs at is item, screen which refers to serching for item type section will be opened. After selecting an item on the serching screen, when you click the check button, the screen is closed and the keyed name of the selected item is entered in the corresponding field. in this case, the onchange method which was put in the field in the previous version of sp12 is activated, but the corresponding event does not work from sp12 version. So, i uploaded the above information to the forum a few months ago, I've heard that you had been aware of the bug and planned to fix it a later version. But the same bug occurs again in the sp14 version. Can you confim this again?
    eli_donahue
    Hi jing9, It looks like this issue has been fixed in pre-release builds of Aras 11 SP15. The fix should be included when 11 SP15 is released. In the meantime, you can contact Aras Support ([email protected]) for a hotfix. Eli
