RaptureLazarus's avatar
What is the correct way to parse DateTime on a server side onAfterGet event?
Hi everyone.
I'm currently trying to evaluate the current date and a date property however, when I try do parse the string provided by getProperty, it gives me the error:
String was not recognized as a valid DateTime.
I can confirm the property is of the Type: Date and Pattern: Short Date.
My relevant code:
for (int i = 0; i < this.getItemCount(); i++)
    Item thisItem = this.getItemByIndex(i);
    string dateStr1 = thisItem.getProperty("_calibrated_next","");
    DateTime date1 = DateTime.Parse(dateStr1);
The only thing that I can think of that may cause this error is the date format conversion when localized from neutral UTC, but I couldn't find much in the Aras documentation related to this.
Thanks
  • So, strange enough, we had to restart the server machine and it worked flawlessly after that.
    Anyway, thanks for your help once again.
  • This might be because the dateStr1 property may be empty string. Can you try below code.
    if(!string.IsNullOrEmpty(dateStr1))
    DateTime date1 = DateTime.Parse(dateStr1, CultureInfo.InvariantCulture);
    Thanks
    Gopikrishnan R
    • RaptureLazarus's avatar
      RaptureLazarus
      Hi, thanks for your response, It seems you are correct, the string is empty., however the _calibrated_next value is displayed in the grid and item itself.
      So it definitely should be getting a value.
      • Gopikrishnan's avatar
        Gopikrishnan
        Accelerator II
        Hi
        1. Check whether the property name is correct.
        2. Is this _calibrated_next is property in item type or on the form ?
        3. Debug the method and check the values
        Thank You
        Gopikrishnan R
