Kai_Kircher's avatar
Kai_Kircher
What is the best way to validate whether an item has a parent?
I'm trying to send an email on promotion to "Released" of Parts when a couple of criteria are met, the parts being of a certain custom classification we've added, and them not being used in another BOM anywhere (i.e. they're top-level Parts being released).
What's the best way to go about checking whether the part is a top-level part (i.e. doesn't have a parent)? I've tried isRoot(), getParentItem(), and getProperty("source_id"), but I'm either misusing those or for some reason they're not working for my case.
This is what I have tried so far (this method is attached as a Post method to the lifecycle transitions to Released, and it is generating the emails, it's just not limiting it to only the times when it's a top-level BOM, like I want):
Item myResult;
if (this.getProperty("classification", "") == "Hull Assembly" && this.isRoot() == true)
        //email code
return this;
//or
Item myResult;
if (this.getProperty("classification", "") == "Hull Assembly" && this.getParentItem() == null)
        //email code
return this;
//or
Item myResult;
if (this.getProperty("classification", "") == "Hull Assembly" && this.getProperty("source_id", "") == "")
        //email code
return this;
  • Hi Kai Kircher
    Easiest way to check whether the item is top level item or not, you can use below code
    Item myResult;
    if (this.getProperty("classification", "") == "Hull Assembly")
    Item checkIsRoot = this.newItem("Part BOM","get");
    checkIsRoot.setAttribute("select","id");
    checkIsRoot.setAttribute("maxRecords","1");
    checkIsRoot.setProperty("related_id",this.getID());
    checkIsRoot = checkIsRoot.apply();
    if(checkIsRoot.isError())
    //email code
    else
    // This item has been used in some Part as BOM
    return this;
    Thank You
    Gopikrishnan R
  • Hi Kai Kircher
    Item myResult;
    //email code
    else
    return this;
    Thank You
    Gopikrishnan R
