What is the best way to secretly observe my users (to see if they use specific ItemTypes)?
Hi community,
I have a couple of custom Federated ItemTypes and TOC views that I designed many years ago for certain data renderings. Some of them are very old and I don´t even know if anyone still use them.
I either want to update the views to more modern UI and coding standards OR delete them if they aren´t needed anymore.
What’s the best way to find out which ItemTypes are being used?
I want to avoid to make a "survey", cause we all know how that ends: The users who matter won’t answer, and the rest will just get confused.[emoticon:d6dd260102fd406884fc96b8bc59760b]
My favorite solution: User select certain elements in the TOC -> a new System or server log entry will be created.
Unfortunately the limiting factor for my favorite solution is the current used Innovator 12SP7. The TOC in this EOL version isn´t CUI based yet. CUI would make the task much easier to solve.
I want to avoid to customize the TOC logic in the codetree just for this use case. How would you solve this task?
Thanks for any idea!
Hi Angela.
This might be a bit drastic, but what about making the ItemTypes in question inaccessible from TOC for a period of time and seeing if anyone complains?
