8 years agoCommunity Manager
Hi Popeye,
I'm not sure it's easily possible to get the local path to the vault without directly reading the XML. Could you let us know what you're trying to do with the local vault path? You don't typically need to manually access the Vault, so there might be another way to achieve your use case.
