8 years agoCommunity Manager
I was not able to reproduce this issue when I tested this last week. This week, I tried manually updating the password for the vadmin user to ensure that some value was set for the
pwd_is_set_on property which is set to NULL by default for all of the standard users.
After making this change, I am able to intermittently see this issue where .svg images are not displayed correctly. In my environment, it seems that this issue only occurs after I am logged in for 5 - 10 minutes. I don't have any issue viewing an .svg image if I view it immediately after logging in. I'll collect some logs on my end to try to track down the root cause of this behavior, but is this consistent with what you're seeing in your system?
___________________________________
