majorbyte
8 years agoIdeator III
After running this same query in a clean database, I got the following results instead: pwd_is_set_on max_pwd_age_value diff NULL NULL 5628In that clean that database you have, create a new user, give him access to tp_image and set his maximum password age to 90 days. Login as that user and upload an SVG, wait for approx. 10 minutes and open the image and it should display the following: https://imgur.com/a/QKXyy Login as admin in a different browser (so keeping the user you just created logged in) and remove the 90 days password age from the newly created user. Switch back to the user's session, close the image and open it again and you'll be able to see the image again.
