8 years agoAccelerator III
Hi Chris,
Yes, it is done on the onChange event of a HTML object, see code below:
The validation behaviour doesn't seem to be consistent. If I make the textbox from invisible back to visible, the required validation is still triggered, when there is a value in the textbox.
<select id="team_list" onchange='setTeamId()'>
</select>
<script language='Javascript'>
function setTeamId()
var select = document.getElementById("team_list");
var selectedString = select.options[select.selectedIndex].value;
var cTeamId= document.getElementsByName("team_id");
var c;
for (c = 0; c < cTeamId.length; c++) {
if (cTeamId.type == "text") {
cTeamId.value = selectedString ;
</script>
