paul_sheehy's avatar
paul_sheehy
using the SQL item type as a view
Querying a SQL view I built in SSMS from an Aras server method: string SQL_View = "innovator.my_custom_sql_view"; string SQL = "select * from " + SQL_View; Item SQL_qry = inn.applySQL(SQL); Th...
  • Gopikrishnan's avatar
    Gopikrishnan
    Hi Paul
    You can use below method to get the required view. I used item_number of NCMR as ID is unique for each item type
    //Verify the Item type name in system
    var ncmrItem = inn.newItem("NCMR MANAGEMENT", "get");
    ncmrItem.setAttribute("select", "id,item_number");
    ncmrItem = ncmrItem.apply();
    if (ncmrItem.isError())
    return inn.newError("No NCMR Item Found");
    else
    var ncmrIdList = new List < string > ();
    for (int i = 0; i < ncmrItem.getItemCount(); i++)
    var ncmrOneItem = ncmrItem.getItemByIndex(i);
    //I'm using item_number here as ID is unique for each item type and we might not have same ID used for Part and NCMR. If you want to use ID, then change item_number to id
    ncmrIdList.Add("'" + ncmrOneItem.getProperty("item_number", string.Empty) + "'");
    var partView = inn.newItem("Part", "get");
    partView.setAttribute("select", "id,item_number");
    partView.setProperty("is_current", "1");
    partView.setProperty("state", "Released");
    partView.setProperty("item_number", string.Join(",", ncmrIdList)); // Change it to ID if you want to use ID instead item_number
    partView.setPropertyAttribute("item_number", "condition", "not in"); // Change it to ID if you want to use ID instead item_number
    partView = partView.apply();
    if (partView.isError())
    return inn.newError("No Part item found using this criteria");
    else
    return partView;
    We can SQL also but it is good practice to use AML as SQL directly interacts with tables and other server events will not be triggered.
    Views in database is created for Poly Item and are system created. If you want to use SQL for any complex get query, you can use stored procedure and call the SQL Process in your method
