- Former_MemberAccelerator IIIAlso it will be helpful if you could share which ui framework (reactjs, angular, angularjs, vuejs or any other UI js lib) may work well for custom ui development. Thank you.
- eli_donahueCommunity ManagerHi ke, We don't currently have any samples available for ReactJS, however there is a sample application community project that uses AngularJS and the RESTful API introduced in Aras Innovator 11 SP12. I'll add a ReactJS sample app to our community project idea backlog. In the meantime, you might be able to find some sample apps online that you can use with the Aras RESTful API. Eli
Eli Donahue Aras Labs Software Engineer - srijaIdeator I
I hope this may help you -Once have a look -www.digitalocean.com/.../how-to-create-custom-components-in-react.Otherwise if you any queries regarding React js Tutorial visit here. you can get a complete detailed UI framework (react.js,angular.js)
Regards,
Srija
