riaanh's avatar
riaanh
Using a search dialog for federated data
Hi there,
I am trying my hand at a bit of data federation. I want to populate a text field with a value from another SQL database.
The plan is to run a script when the user clicks on the text field on the form.
This script then calls up the Aras search dialog, but upon searching, bypass the Aras search, and do a SQL query on the external db and pass this back to the form.
Am I on the right path? If so, how do I run my c# code, with the SQL query instead of the default Aras search?
So I am effectively looking for a script hook in the searchdialog function.
Kind Regards
Riaan
  • Ok, I am getting there. Created a federated item, then attached my script with the SQL query to the "OnGet" hook. Now when I run the searchdialog with this federated item as "itemtypeName" this script runs.
