Aaba's avatar
Aaba
8 years ago
Use of HTML5 in aras
Hi Guys, As per my information Aras is upgrading to the HTML5 in near future. Currently we are working on the DOJO script and if Aras is planning for HTML5 then it will be easy for us to upgrade later. Anyone please guide me on this as which script shall we use? If we continue to work on the DOJO script and will it be possible to upgrade later? Is there any HTML5 API provided by Aras? What is the diff between Aras Dojo and Aras HTML5? Thanks.
  • eli_donahue's avatar
    eli_donahue
    Hi Aaba, Aras doesn't provide a Dojo or HTML5 API - we just use a combination of client-side technologies to build the Aras Innovator web client. You are able and welcome to use any framework or API for your development. If you're interested in the APIs provided by Aras, you can find the .NET API here and the JavaScript API here. Aras Innovator 11 SP12+ also supports a RESTful API. This blog post contains some sample calls to get you started. Eli
