Hi Gopi,
Thanks for the response.
I tried to promote the Part at "Under ECO submission state" that was already cancelled in a workflow process.
But i received the error as shown below,
No promotions available is shown.
I checked the part life cycle map and i can see the transition from "Under ECO Submission" state to "Work in Progress" state but the Role was "Aras PLM". I even changed that to super user and tried promoting but same error appeared.
And after cancelling the Workflow process still i can see the preview property window shows the first item in grid as Active only. rest all shows closed.
open the item and can see the state as closed. So confusing.
Note:- workflow process is cancelled using sql query only. Please is there any other ways to fix this?
Thanks,
Bala.
Update using SQL query will prevent all server events execution and it is not recommended.
Can you try adding your user account to ARAS PLM role and relogin to application and try promoting it
- sbala6 years agoCreator I
Thanks Gopi!! It worked after adding myself in Aras PLM role. I can able to promote the parts.
- Gopikrishnan6 years agoAccelerator II
Glad to hear.. Stay safe [emoticon:c4563cd7d5574777a71c318021cbbcc8]
Thank you!! you too stay safe:)
