Bala,
Have you made the changes to the workflows (Workflow Processes) for the individual DRBs(ItemType?) that you are having problems with? Once the DRB is created, there is a Workflow created specifically for it. Updating the Workflow Map will only affect new ItemTypes created.
- sbala6 years agoCreator I
Hi Nathan,
Thanks for your response. It worked for another similar DAB activity. I added the DAB group identity in the workflow process of DAB activity and that fixed the issue.
Thanks,
Bala.
- Nathan6 years agoCreator III
I'm glad to hear you were able to solve the problem.
Hi Nathan,
There is another similar issue that am facing . Pls ref the error msg below,
This is also occurs while voting to DAB Activity from DRB activity. I added the identity group in workflow process of that part and gave update and other necessary access permissions. But still user couldn't vote for that activity and same error occurs. Lifecycle state permissions of the subworkflows DRB and DAB are also added with those group identities and given update permissions.
What am i missing here? Please advice.
Thanks,
Bala.
