FrankdeBruijn's avatar
FrankdeBruijn
Ideator II
Uploading multiple document revisions with the batchloader
Hi, I have the following (legacy) structure of documents and files: DOC-0001 Rev 12 State: Superseded File abc_12.dwg File abc_12.pdf DOC-0001 Rev 13 State: Superseded File abc_13...
    Hi Frank,
    I haven´t done this yet, but once had to spend some time for this use case. Do you use automatic versioning for documents? Than Innovator might create the new revisions for you. It´s maybe possible to import all items at one. Your import file just should have the correct order of the items, so your documents don´t get mixed up. You can later overwrite the used major_rev with the different start number and promote the affected Items to the state you need with a seconds batch call (just manipulate the Lifecycle temporary for this task).
