cldavis_smcusa_com
2 years agoCreator I
Updating a property on a vote with a server side method.
I am trying to update a property after a user votes on the item in the workflow.
I have this as a Post Method on the workflow server side C#. The variables seem correct, but the property is not upd...
- 2 years ago
Have you saved the changes to the controlItem object after setting the property value? According to the documentation stackoverflow.com/.../updating-an-object-property-in-c-passing-the-property-as-a-parameter of the Innovator class, you need to call the updateItem method to save changes to the database.
