8 years agoCatalyst II
Thank you Martin and Stefan for your input!
I tried to use the version attribute in combinaton with my AML query, but still wasn´t able to change the minor_rev without addtional SQL.
I normally try to avoid using direct SQL or SQL procedures. But in my case, nothing else worked so far.
A little bit suspicious: Even Aras uses SQL to change the Minor revision:
github.com/.../MinorRev Handling.xml
The example recommends to check the minor_rev ReadOnly checkbox in the Property settings. But I didn´t check this one. So my minor_rev should be fully editable.
Can one of you confirm, that you are able to overwrite your minor_rev property with AML?
