haider
4 years agoIdeator III
No actually this is a brand new property I created
Jayrajvh
4 years agoCreator II
Do you have some other property marked as unique on Item Type SubContract1?
- haider4 years agoIdeator III
Nopes there is none also I tried changing the name of the property as well but it would give the same error.
- Jayrajvh4 years agoCreator II
Can you share some screenshots? Like
1. filter properties which are unique
2. Items grid of Subcontract1 to just have glimpse of data available- Gopikrishnan4 years agoAccelerator II
Are you trying to make the property from not unique to unique ? if yes, Is there any Subcontract1 item already created in system ? If yes, then set some unique value to those data and then try making this field to unique.
