9 years agoAccelerator III
Hi Eli,
Thank you very much for your response.
The below code is used to iterate through the existing values of the list - "ManfPartList" and then set all the values to currSelCell using the setCombo(labels,values).
This works fine in Aras 9.2 but I am unable to set list values in 11.5 using the same code.
Request you to please let me know the resolution for this issue.
try
var delimiter = "$";
var labels = " ";
var values = " ";
var listItemQuery = new Item("List","get");
listItemQuery.setProperty("name","ManfPartList");
listItemQuery.setAttribute("initial_action","get");
var ListResult = listItemQuery.apply();
var ListId = ListResult.getID();
var valueItemQuery = new Item("Value","get");
valueItemQuery.setProperty("source_id",ListId);
valueItemQuery.setAttribute("initial_action","get");
var valueItemResult = valueItemQuery.apply();
if(ListResult.getItemCount()>0)
for(var i=0;i<valueItemResult.getItemCount();i++)
var thisValueItem = valueItemResult.getItemByIndex(i);
var thisLabel = thisValueItem.getProperty("label");
labels = labels + delimiter + thisLabel;
var thisValue = thisValueItem.getProperty("value");
values = values + delimiter + thisValue;
currSelCell.setCombo(labels,values);
return true;
catch(e)
//alert(e);
Regards,
Charita
