dlindinger
9 years agoCreator I
My best guess is that you have a method hooked on the part itemtype that is being triggered when you issue the version command and that method is throwing the error. Here are some things to try (in no particular order).
#1
- delete the part 100 you created earlier
- rerun the aml to create the part
- Run this AML to version
- Retest in an out-of-the-box database to confirm that my environment and your environment are both working the same
- Temporarily unhook the part's server events
- retest with the aml
- What happens if you create a part in the UI
- Save, unlock, and close the part
- Edit the part in the UI
- Save, unlock and close the part
- Any errors?
