8 years ago
UI Widget Value for Foreign Data Type
Hi All, I have a question when I created a custom form within a form(Side tab within a standard form) I want one field to be as foreign so for that I created using Item Property Template. I need to know the UI Widget Value for Foreign Data Type field for side tab form within a stanadrd form. Can anyone answer? Thanks
  • eli_donahue's avatar
    eli_donahue
    Hi Sidmalhotra, You can use a text field to show your foreign property value. If you set the data source of the field to your foreign property, the value should display just like any other string property. Eli
