Transfer a property value to another item's property
I'm working with AML to update the Data in aras innovator. i'm stuck because i can't seem to transfer a property from one item to another.
I have 2 items A and B. let us say that item A is a part and item B is a document.
item A has a property called x which has the value "test"
I want to transfer this value to the property y of item B
this is my progress for now:
<AML>
<Item action='get' type='document' version='0' id='123456' >
<y>
<Item action='get' type='part' select='x' id='987654' >
</Item>
</y>
</Item>
</AML>
Thank you in advance.
for your use case you probably need two queries. The first one gets a value from the Part and the second one edits the Document.
This not something you can do with Innovator Admin or similar tools. But it´s easy to do with a Method. You even could directly set the values via SQL (if you are familiar with the data structure and know what you do).
